The Wagon, two 12's, few thousand watts.
Ah yeah, you can't see the subs!
They're Elevation Audio SQX 12's, running off a Digital Designs Z1, wired at 1ohm, rising to 2ohm at 40Hz, clamped about 2000watts.
Fronts are currently still running off the headunit, haven't gotten around to adding an amp for them yet.
This is where I put the round over internally that gained 0.7dB.
where else should I try adding roundovers?
Yes, thats what the end of the port looks like with the double round over, port is 120mm wide, but only 60mm from the back wall ;)
back of the box in those corners, love a good wagon build that box looks clean as fuck dude!
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
I say at the back corners of the box. That should give you another half db or so.
EDIT: Goddamn ninja'd
2007 Pacifica
your box is clean as hell btw. :popcorn: nice numbers
2007 Pacifica
Thats actually where I tested some roundovers today, and gained nothing, possibly lost 0.1dB :P
because the woofers are firing up, I think it changes a few things, so tomorrow I'll try along both sides, behind each woofer, if that makes sense.
Thanks for the input ;)
