The Wagon, two 12's, few thousand watts.
Where did you get that deadener?
2005 Grand Prix GXP ya its got a V8!!
3 DC Audio XL 15s in 12 cubic wall
2 DC Audio Pai 2000.1s Strapped at .5ohm daily
1 Sundown Sax 100.4
Apline Type R 6.5 Components in front
4 Rockford Fosgate R1693 6x9s behind seats
3 Stinger Spv70 batteries in rear
1 Stinger Spv45 up front
custom crossovers ;)
3800Hz, midwoofers are at 2ohm, tweeter is 8ohm.
Tweeters are Peerless 811435, spent ages figuring out where and how to mount them...
Facing opposite side headrests which also means when the doors are open they face straight back ;)
But because they're square, and I have the electric mirror controls on the other side of the car, there really weren't many options in the end.
Might chuck some black grille cloth over the whole thing ;)
I chucked some Pioneers back in, as they'd always seemed to be louder than the Option Audios...
well, chuck in some venting (drivers window, and both rear windows) and we end up with this...
Good numbers! Doors look really good. Can't even tell that you have all of that in there. Really diggin' the box too.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Been working on repairing a Digital Designs Z1 amplifier I bought ages ago, only to find it wasn't working properly, and appears to have been repaired by a monkey, at least twice before I got it conf.gif
This is the type of thing I was greeted by when I removed the bottom of the case; I'm fairly sure it was repaired without even removing the PCB...
SO, I pulled the PCB out, and went from there...
Not much I could do about the missing pads, but I removed the board, took all the power supply fets out, and cleaned the board up as best as possible ;)
I also removed and replaced the resistors that drive the mosfets, as some had a nice coating of black crud from the fets that had exploded next to them, all had been replaced before and didn't look the same, and some were damaged...
I slid the board back into the case, to work out where/how the fets needed to be soldered to the board, and went to work ;)
