My max dimensions to work with are 54x24x24 an I want to tune it around 34-35 it will be inside a car backseat removed need any tips on air space port design sub direction port direction and I'm going for spl but still want it tuned low any help is greatly appreciated thanks!!!
8 sundown sa 12s walled
Saz3000 at .5
HO alt
All ofc Sky high wire
Alpine components
Rockford power mids
imagesCAA9EA5N_zps0f411022.jpga5ec9a01-b60c-4312-9001-236b48dfe6b0_zpsb01ef146-7fd0-47c3-90e9-f1a2d4595b03_zpsimagesCATNMRMV_zps66a8566a.jpg
93 Buick roadmaster I've tried a lot of dif
Subs an boxes
In the trunk an it's jus not as loud as I want lol
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
I had in mind a box that was 54 x 24x24 that's 18cu ft sub up port up but didn't really kno what to do about a port an how
To get it
To 35hz a lot of the online port calculators are giving me a hard time
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
Posted (edited)
I guess you are not factoring in displacements, check this suggestion, is not final or anything, just for you check, also this subs are recommended for up to 33Hz tuning, you barely have the space for them, port/subs front firing:
Enclosure Specifications:
Fb = 33.8 Hz
Vb = 12.628 ft^3
External Height = 28 in
External Width = 54 in
External Depth = 22.25 in
Port Width = 8 1/8 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 45 1/8 x 26 1/2
Front Internal = 43 5/8 x 26 1/2
Back = 54 x 26 1/2
Left & Right Sides:
Side 1 = 20 3/4 x 26 1/2
Side 2 = 21 1/2 x 26 1/2
Top & Bottom = 54 x 22 1/4
L Port Internal Assembly Parts:
Front to Back = 12 5/8 x 26 1/2
Extension = 2 x 26 1/2
Edited by Joe X
I would try for less deadly alternatives if feasible first, also what car are you placing this in?
its no more deadly than a wall. as long as its got a solid foundation and is secure, there shouldnt be any issue.
A wall could be pretty deadly, I have not heard yet about crash tests on vehicles with walls yet though. :)
Is there anyway I could change the port dimensions on that plan tho to be around 34hz
I kno 31
Wud hit sum nasty lows but I haven't seen a lot of ppl put up real high numbers tuned that low before an is that plan port middle and l port toward each sub
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
I kno 31
That is a single port on the side, and takes very little internal volume, I'd like to have some more depth if that's possible.
  • Who's Online   1 Member, 0 Anonymous, 780 Guests (See full list)
