Box design help please
Slim337
I need help with a box design for 4 12's. It's going in a Yukon.
The max dimensions
4ft wide
3ft tall
Deep as needed
Sub specs.
Fs (Hz): 26.3
Qms: 7.695
Vas (ft3): 2.111
Xmax (mm): 13.25
Xmech (mm): 19.88
Qes: 0.778
Re(ohm): 4
Voice coil: Dual 2ohm
V.C. Diameter: 2.50
BL : 13.05
RMS power: 1000
Max power: 2600
Qts: 0.706
1w/1m spl (db): 83.3
Overall dia.: 12.625
Overall height: 7.50
Mounting depth: 6.75
Cone diameter: 11.125
Flange width: 0.75
Flange height: 0.75
Magnet diameter: 6.25
Magnet height: 2.25
Ok check this, within you dimesions and mfr suggested specs subs up/port back:
Enclosure Specifications:
Fb = 33 Hz
Vb = 6.047 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 19.75 in
External Width = 28 in
External Depth = 28 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 28 x 28
Left & Right Sides = 26 1/2 x 17 1/2
Front & Back = 28 x 17 1/2
Port Quantity and Dimensions:
Number of Ports = 2
Pipe Port Diameter = 6
Pipe Port Length = 18 3/4
If you are overdriving your subs or seek a particular tuning some adjustments can be made.
Let me know any qustions.
Is there any way u can design it in a wall. I down sized my system cuz I hav a family now & need more room from storage when traveling. I had 4 T1 15's in there b4. So I like the low bass. I know I won't get that as much with the 12's. But I'd like it to be able to get low as possible for daily listening. Thx Joe.
  • Who's Online   0 Members, 0 Anonymous, 1046 Guests (See full list)
