The subs are 2 PR10D4V2 Memphis... i am making my first box ever gonna start out with the recommended box for slot port,
http://www.memphiscaraudio.com/documents/2012%20Enclosure%20RecommendationsCONSUMERS.pdf
PR10D4V2/0 12cf/250w/2 1.50cf gross/10.5”x1.25”x15.5”/42Hz
Is the 10.5 x 1.25 x 15.5 the total box length? im lost maybe i should start with a sealed box :P! any help is needed and throw some tips at me!
Those dimensions are for the port, the box can be any dimensions it just says 1.5 cubes gross.
Do ported, it's worth it.
How much power are you going to run those subs on, and what kind of music do you listen to?
1997 Chevrolet Silverado Extended Cab, 350 Vortec
Things to come at some point...
Build Log: http://www.stevemead...2200ds-133-ohm/
Rap, but im just building something to sound decent for a little and then sell to a friend, im not worried about low tuneing i just need it to be impressing to the ears and last awhile so my friend dont complain they blew , and a 500.1 amp
I wish i could put my 1200.1 amp on them and blow em to pieces tho haha
you need to set your gains right, then you probably won't blow your subs so much.
download torres calculator and play around with that.
definitely go ported
More box builds
I'm with captain stupid.
Posted (edited)
I wish specs were giving to me like how your avatar is im terrible at designing anything haha. let alone how to read specs i don't know which length is which.. :P Not ment to be in the box building industry just doing it for fun. Who knows this could be my thing!!!
EDIT: I only blew one memphis but thats because i had the wrong box ( throw them in the old one with not enough space (sealed)
Edited by BillKessel
Doing something like this would be easy to make, decent for two 10s, and would probably fit in most trunk cars.
Oh and one sheet of MDF.
That is honestly awesome, some day i will have to learn how to draw the box like that, port out the side, wouldnt port out the back be best? (Not arguing with your box design but its what i hear)
For a trunk car non-sealed up yes port back is loudest most of the time.
The car it is going in was never mentioned so I just did that port to cover a lot of applications :P
Posted (edited)
Thats fine! :) I was just making sure, makes perfect sense. one day you will have to teach me to use google sketch up like that! haha
and im assuming the bottem piece is 30x18 aswell?
  • Who's Online   0 Members, 0 Anonymous, 675 Guests (See full list)
