Rise
Rainman215
I've been reading a lot that 2 amps will have more rise then 1 amp.
Like 2 3500s vs 1 7k amp
I always thought the enclosure determined rise. Somebody explain to me please.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
^ I too would like to know this
Current Set-Up
2004 Chevy Tahoe
Subs: 2 DC XL 15's
Box: 8.5 ft^3 @ 38hz
Amp: Amrican Bass VFL 500.1
Alt: Db Electric 250amp
Batts: 2 Kinetic HC 1200s
Radio: Pioneer 3300UB
Doors: Pyle Pro Mids/Goldwood Tweets
Amp: Alpine MRP-300/Hifonics ZX80.4
Wire: Kicker 1/0 Guage
Termlab: 153.1 Outlaw Style @ 46HZ
if anything more amps will have less rise. Think of it this way. your rise is going to be there. however you can have that rise going to one amp or you have the same rise going to two amps. You will find many people who argue this both ways. You'll also get the same argument for strapped vs unstrapped amps as well. Nate you have two 3500s right? You can test this. Strap your amps and then try them gain matched. See what nets you more.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
With 2 amps strapped @ 1 ohm, each amp will have .5 load. So after rise, it will be closer to 1 ohm load rather then 1 amp @ 1 ohm will rise higher.
This has zero to do with the topic. its still the same amount of rise with a lower starting point.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yea but no clamp meter
you have a termlab or spl meter? You can do a test to see if you gain one way or another. Thats what its all about in the end. in theory a gain in DBs in the same install will have the power as the variable to determine change.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1074 Guests (See full list)
