CoritaAlterado Posted March 9, 2012 Report Posted March 9, 2012 I have a honda civic lx...so the trunk is very small. I've been looking into Skar's IVX 15 inch sub, its nice and affordable. Would it be possible to build a ported enclosure that would fit into a opening thats about 25 inches by 45?
Joe X Posted March 9, 2012 Report Posted March 9, 2012 The ivx 15 works on 3.5 cubic feet so the following can fit through the hole: Enclosure Specifications: Fb = 35 Hz Vb = 3.507 ft^3 Subwoofer Mounting = Front Mounted External Height = 23 in External Width = 33 in External Depth = 14 in Port Width = 2 3/4 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 33 x 23 Left & Right Sides = 12 1/2 x 21 1/2 Top & Bottom = 33 x 12 1/2 L Port Internal Assembly Parts: Front to Back = 11 1/8 x 21 1/2 Extension = 14 13/16 x 21 1/2
Reks19o9 Posted April 2, 2012 Report Posted April 2, 2012 I have a 94 civic would that box also work for a kicker cvr 15?
Joe X Posted April 2, 2012 Report Posted April 2, 2012 If you have the space (check your height) try the following for the 15" CVR: Enclosure Specifications: Fb = 36 Hz Vb = 4 ft^3 External Height = 23 in External Width = 33.5 in External Depth = 15 in Port Width = 3 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 33 1/2 x 23 Left & Right Sides = 12 3/4 x 21 1/2 Top & Bottom = 33 1/2 x 12 3/4 L Port Internal Assembly Parts: Front to Back = 9 3/4 x 21 1/2 Extension = 10 1/2 x 21 1/2
Reks19o9 Posted April 3, 2012 Report Posted April 3, 2012 Thanks for the help I currently have two 15 cvr's in a 3.5 cu ft box another person said to use only one in a bigge box
