installed alt now I'm at 12.3v. please help
i just put on my dc power 270 amp alt and now from idle all the way up to 3000 rpm it sits at 12.3. I have tested it with a damn and it matches my VM in my car. with stock alt I stayed around 14.4 until I turned my system up it would drop to the low 13 high 12 now it's dipping down to the 11s and idea what might be my problem?
2 15" DC LVL 5' crescendo 5500 yellow top under the hood and two xs power d3100
Big three upgrade
Rockford Fosgate T162S components in front
Rockford Fosgate T152 in the back
Dynamat everywhere
Same thing happened with my singer alternator! I'm switching pulleys today and seeing if it fixes my problem
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
well what would be the cause and how does pulleys fix it? are you getting bigger ones? when it comes to engines and even alts I know little to none.
Big three upgrade
Dynamat everywhere
Guest DC Power Kyle
Sounds like the alternator isn't turned on. Check your connections and if you're still having problems call us. It's nothing about the alternator's turn on speed if it's constantly at 12.3 volts. Also, what vehicle?
A smaller pulley would cause the alternator to see higher rpm
(1) Mechman 240
TEAM NWSPL
155db outlaw
it's a 2000 Toyota 4runner it's plugged in and I have checked all the hook ups everything seems right I just called and left a message
Big three upgrade
Dynamat everywhere
okay y'all dont be to mean but it wasn't plugged in all the way :) but NOW that it's plugged in I'm still only seeing 13.9 from idle up to 3000 rpm?
Big three upgrade
Dynamat everywhere
  • Who's Online   0 Members, 0 Anonymous, 1505 Guests (See full list)
