Kidd_Bass Posted March 11, 2012 Report Posted March 11, 2012 Ive been B.S. around with box calculators and other things but Im not completley sure on what to do I just need some help this is my first build and I know it wont be perfect but I want it good enough I was thinking about dimmension like this : 21 " HEIGHT, 36" WIDTH, 21" DEPTH if you can send some designs please Max Dimmensions: 28" DEPTH, 22" HEIGHT, 47" WIDTH Model Subwoofer: 2008 2nd Gen Fi BTL 18" Amp : Soundstream Rubbicon 2500 watt Please help if you can
KOZ89 Posted March 11, 2012 Report Posted March 11, 2012 i wouldn't make it so wide, for one woofer, i'd bring it down to low 32-35 for width, to me it seems you would be tunning the box to about 25hzish, correct me if i'm wrong but that's what i was getting for box calculations on your desired dimensions I'd go with Height - 22-24ish" Depth- 22" Width - 32-35 ish still working on my sketchup skills so i wish i can help you build coming late April, early May build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/ 1997 Dodge Ram 1500 Slt Laramie Amplifier - AQ3500d.1 Sub - DC LVL 5 18" Highs - (2x) Selenium ST-350 Super Tweeters 8ohm Mids - Selenium 6" 200w midrange 6W4P (pair) Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch Wiring - XP Flex 25' Red, 25' Black Alternator - Mechman 270amp Battery - XS power D3100, 1- Yellow top front more to come...
Kidd_Bass Posted March 11, 2012 Author Report Posted March 11, 2012 i wouldn't make it so wide, for one woofer, i'd bring it down to low 32-35 for width, to me it seems you would be tunning the box to about 25hzish, correct me if i'm wrong but that's what i was getting for box calculations on your desired dimensions I'd go with Height - 22-24ish" Depth- 22" Width - 32-35 ish still working on my sketchup skills so i wish i can help you I Was trying to tune the box to about 32-33 hrtz If you think that it will hit the lows better with those dimensions I will try it
Kidd_Bass Posted March 11, 2012 Author Report Posted March 11, 2012 That looks Perfect just wish that I had some specs with it but I will try to make due with the pictures
