TheNewbies build - DC, Skar Mitsubishi Eclipse FINISHED
Decided to make up an amp rack today, nothing fancy.. well to you fellers but being my second built I was pretty proud of myself pictures below
Had to use different screws, was digging everywhere
I even cut some of the screws to get them to fit.. I drilled with the tip, and then cut it so it wouldn't go completely through to the otherside.
Put some ledges on it
Test fittin it put a peice of wood under it to hold it because it's not mounted yet, gotta carpet it.
Checking to make sure it doesn't hit, fits great. Sure the SKAR should look fancy there.
Well that's it for now, fuses should be in soon and finally gettin the wire,
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
Nice job man I was waiting to see how you were going to incorporate that hammer into the amp rack but then I realized it was a prop. Pretty sweet though Haha.
Figure I'd smash it if it didn't fit :P thanks I appreciate the feedback definately helps. Constructive criticism is always nice as well. Wish my build wasn't full of a bunch of my replys.
Black or the same color as the box?
This is the switch imma use to turn bass on and off for lame people that don't like it, or to suprise someone.
Fuses 300A
40 feet of Knu OFC 0 gauge will be here tomorrow so i'll have some picturesof the wiring. I can't wait getting excited. Next up amp and I'm ready to roll.. By the way any suggestions on a component set? On a side note I hope the Xs975 in the back with the wet cell in the front will be enough
