I got my fulcrum Trigger Kit in today for my Glock 34 and figure I would post pictures of how to install it.
This is what came in the kit.
Gun and necessary hammer and punches
First step is to separate the upper from the lower.
Next you have to remove the Ejector Housing pin, Locking Block pin, and Trigger pin. Make sure that you do no lose these pins.
Next remover the Locking Block by using your punch to pry it up and remove it. And remove the Slide Stop.
Next remove the stock trigger assembly by pulling up on the ejector.
Next install the complete Fulcrum trigger kit in the same way that you removed the stock. Drop the locking block back in place and put the Slide stop back in place.
Next install the trigger pin, making sure that all of the holes are lined up before installing.
Next install the locking block pin, This one you have to be careful when installing. The slide stop will have a spring that has to go under this pin. Once the pin is about 3/4 of the way in you will take your punch and push the spring down under the pin and then finish installing the pin.
Last, install the ejector housing pin.
Now reassemble the upper and lower and you are done
The trigger has 2 set screws, 1 front and one back that allows for trigger adjustment. Use these set screws to adjust the trigger travel to your specifications. This will be a process that you will have to do over and over until you get it just how you want. Just pull the trigger kit out and make your adjustments and then reinstall.
I have not taken it to the range yet, but overall the trigger pull is much shorter and smoother just by dry firing. I will get to the range in the next few days and get a live fire report.
  • Who's Online   0 Members, 0 Anonymous, 610 Guests (See full list)
