so, I had this box idea all done had it the way I wanted it and then made a ROOKIE mistake.... forgot to incorperate the Sub Displacement in the whole Equation......................................................
So heres what im working with, If someone wants to send me some measurements or a pic/measurements of what im needing that'd be great!
Heres My Maxes
34" W
18.5" H
20" D
2x 15" American Bass DX15s
Sub Displacement 6.824 Each
Want it Tuned to ~35Hz
Im building this box a certain way for a certain reason (it will be used in a boat and xcab truck)
The 2 subs on the 34" x 18.5" face and the port is going to come out the side the 18.5" x 20" part (this is so I can lay the box on its back in the boat have the subs facing skyward and the port firing into the boat)
Truck
Polk 4x6 Plates
Polk 4x6
Polk PA660 4Channel amp
JVC USB Deck
Wifes Car (under construction)
Polk MoMo 6.5" Components
Polk 6x9s
Polk Pa660 4Channel amp
Still trying to talk her into a sub or 2
Boat (under construction)
Polk 5.25" Components
Polk 6.5" Components
2x American Bass DX15s
Polk PA660 4Channel
2x Polk PA880 Sub Amps (hopefully)
You can pay RAM Designs like $20ish dollars to design you a box, and have it designed properly.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
haha, no thanks... I can do it but ive been working on it all day (not really but sure feels like it) finally got it then forgot the sub disp. Ill just start over tomorrow when all the numbers dont look the same lol
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
Heres My Maxes
34" W
18.5" H
20" D
What units is your sub displacement in? Make sure you find it ft^3 if you're using torres
6.824 each is not right
Edited by Loslam
1997 Chevrolet Silverado Extended Cab, 350 Vortec
Things to come at some point...
Build Log: http://www.stevemead...2200ds-133-ohm/
yea its 6.826³ inches i do believe... x2 divide by 12 divide by 12 comes to .0947³ft for the 2
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
Heres another question... whats an adaquet port width for 2x 15s running around 1000rms total I have it figured at 4 1/2"
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
You actually divide in^3 by (12x12x12) to get ft^3. Then multiply by two for subs. Which gives .0079 ft^3 displacement for both subs.
Still seems off, I'd check your info again brother, good luck
yea... i dont know... it says SUB DISP. L so idk if thats sub displacement lineir cause then i have NO idea how to figure that out... lol
http://www.americanbassusa.com/product.detail/product_id/23
Theres the sub.......
Truck
Polk 4x6 Plates
Polk 4x6
JVC USB Deck
Polk 6x9s
Polk PA660 4Channel
http://www.americanb...l/product_id/23
Ahhhh there you go. L means liters, a metric unit of volume.
Convert that to cubic ft = .241 each - so total displacement of 2 subs is .482 ft^3 :)
  • Who's Online   0 Members, 0 Anonymous, 1755 Guests (See full list)
