Crazycaraudio Posted March 16, 2012 Report Posted March 16, 2012 i was wondering if anyone with a jeep cherokee can help me find a place to run my 0 awg power wire. cant find any holes on my firewall to allow me to run it i need it bad. Quote
KillaCam Posted March 16, 2012 Report Posted March 16, 2012 Have you tried going underneath? Quote And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
ShakeNbass Posted March 16, 2012 Report Posted March 16, 2012 run it along the frame best way to do! we did on friends jeep and comes up right back seat. i stop running zero threw a car unless i plan to do alot runs. Quote personal best for 2012 new best 148.4 at 50 hrz on 2500 watts clamped with 2 dd3515 on audiobahn a5000spl 133.3 extreme score 2 dd3515 2004 model dual 2s audiobahn a5000spl amp wired at .5 ohm daily q power ofc zero gauge wire. 4 batteries in trunk
Crazycaraudio Posted March 16, 2012 Author Report Posted March 16, 2012 (edited) i have a 8 awg wire running from frame and i dont like the way it come in the cargo area from the rear hatch do you have its from your friends jeep? of where it comes in the car? Edited March 16, 2012 by Crazycaraudio Quote
ShakeNbass Posted March 16, 2012 Report Posted March 16, 2012 rear set where it folds down there very thin middle there to run it in and its hidden. Quote personal best for 2012 new best 148.4 at 50 hrz on 2500 watts clamped with 2 dd3515 on audiobahn a5000spl 133.3 extreme score 2 dd3515 2004 model dual 2s audiobahn a5000spl amp wired at .5 ohm daily q power ofc zero gauge wire. 4 batteries in trunk
btsteinb Posted March 16, 2012 Report Posted March 16, 2012 just drill a hole in the firewall and put in a grommet. Quote
CleanSierra Posted March 16, 2012 Report Posted March 16, 2012 (edited) just drill a hole in the firewall and put in a grommet. What he said^^^ this is the best way to do it. I ran my wire through a hole I cut with a core bit. Rubber grommets are cheap, find one. Don't expose your wire to all of the elements outside of the vehicle if you don't have to. It may decrease the life of your wire. Edited March 16, 2012 by CleanSierra Quote Im not the one you want to try to troll. Just a fyi for you.
ShakeNbass Posted March 16, 2012 Report Posted March 16, 2012 just drill a hole in the firewall and put in a grommet. What he said^^^ this is the best way to do it. I ran my wire through a hole I cut with a core bit. Rubber grommets are cheap, find one. Don't expose your wire to all of the elements outside of the vehicle if you don't have to. It may decrease the life of your wire. are u kidding me. the wire has coating for reason. it wont even effect it at all. i ran wire for years under car and never had issue and to me lot easier. some cars cant put zero gauge threw the car cuz the plastic on it don't go back. Quote personal best for 2012 new best 148.4 at 50 hrz on 2500 watts clamped with 2 dd3515 on audiobahn a5000spl 133.3 extreme score 2 dd3515 2004 model dual 2s audiobahn a5000spl amp wired at .5 ohm daily q power ofc zero gauge wire. 4 batteries in trunk
CleanSierra Posted March 16, 2012 Report Posted March 16, 2012 just drill a hole in the firewall and put in a grommet. What he said^^^ this is the best way to do it. I ran my wire through a hole I cut with a core bit. Rubber grommets are cheap, find one. Don't expose your wire to all of the elements outside of the vehicle if you don't have to. It may decrease the life of your wire. are u kidding me. the wire has coating for reason. it wont even effect it at all. i ran wire for years under car and never had issue and to me lot easier. some cars cant put zero gauge threw the car cuz the plastic on it don't go back. Not I'm not "kidding" you. Wire inside of a car will last MUCH longer and take MUCH less(if any) abuse that wire exposed to elements. I live in AZ, and wouldn't even consider running my length of power wire under my vehicle. Rubber dry rots here in no time at all. Quote Im not the one you want to try to troll. Just a fyi for you.
Crazycaraudio Posted March 16, 2012 Author Report Posted March 16, 2012 can somebody show me a pic of where they drilled? i dont want to drill in wrong spot. oh yeah i tried find soldering terminals and grommets for 0 gauge at home depot and no luck. Quote
