Sub ideas?
Alright. And um I'm guessing best way to learn to set gains is look through forums???
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Wait tho. The dual 2 has a rms of 1000w? The dual 1 has a rms of 1500w? So how would that work? Our is it easier to go dual 2 with brz 1200.1d wired at 1 ohm to get 1200 rms
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
the fi subs are underated as far as rms and if you get the flatwind and hyperpole it will increase your subs rms, and the only other way to set gains that i can think of without and oscope or dd-1 is to clamp the amp and just set it around 1500 watts for now untill u can find someone with a dd-1 or buy your own
Ok so the 2ohm rated at 1000w will push 1500w or so?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Alright. Thanks for all your help. And they highly recommend getting the cooling option on daily drivers. So should I?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
