KiKaZz74 Posted March 22, 2012 Author Report Share Posted March 22, 2012 Alright. And um I'm guessing best way to learn to set gains is look through forums??? Quote My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
KiKaZz74 Posted March 22, 2012 Author Report Share Posted March 22, 2012 Wait tho. The dual 2 has a rms of 1000w? The dual 1 has a rms of 1500w? So how would that work? Our is it easier to go dual 2 with brz 1200.1d wired at 1 ohm to get 1200 rms Quote My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
jrchevy87 Posted March 22, 2012 Report Share Posted March 22, 2012 the fi subs are underated as far as rms and if you get the flatwind and hyperpole it will increase your subs rms, and the only other way to set gains that i can think of without and oscope or dd-1 is to clamp the amp and just set it around 1500 watts for now untill u can find someone with a dd-1 or buy your own Quote Jeep Wrangler TJ Hardtop Build Link to comment Share on other sites More sharing options...
KiKaZz74 Posted March 22, 2012 Author Report Share Posted March 22, 2012 Ok so the 2ohm rated at 1000w will push 1500w or so? Quote My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
jrchevy87 Posted March 23, 2012 Report Share Posted March 23, 2012 just get the flatwind and hyper pole and as long as your not sending a distorted signal you will be fine Quote Jeep Wrangler TJ Hardtop Build Link to comment Share on other sites More sharing options...
KiKaZz74 Posted March 23, 2012 Author Report Share Posted March 23, 2012 Alright. Thanks for all your help. And they highly recommend getting the cooling option on daily drivers. So should I? Quote My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
jrchevy87 Posted March 23, 2012 Report Share Posted March 23, 2012 np, with your setup i would go with it Quote Jeep Wrangler TJ Hardtop Build Link to comment Share on other sites More sharing options...
