How many batts will I need
This video has the formula's and is fairly easy to understand what total electrical requirements you need.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
My recommendation (because im running the same equipment at the moment) put the largest batt up front that you can fit and throw a d31 in the rear. Also big 3 if you havent, and 1 run + and - to the rear batt. You should be having very little voltage drop off of that setup. And trust that T1500-1 with the right power will bang hard..
Rebuild Log with the SMD
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
99 Lexus RX 300 (sold)
ADDING
Honda - Hertz setup, more to come
Porsche - Fi BL, XS Power, more to come
coming soon..
peep the old rebuild log of the Lexus RX
your trying to make this wayyy more complicated than need be for real
replace the underhood battery a good regualr wet cell will work if need be and do a single 60 to 100ah battery in the back
simple
I really dont get how I am making it complicated, I am just trying to find an accurate way to find out how much battery I need. That is what I want to do, replace the under the hood batt, and add 1-2 more in the back as needed.
TY!
9x5x7.5 Is the largest my front is, and most of their batts won't fit that. Most are just a bit over 5in wide. Also a d3100 won't fit in the back, Like I said I have space requirements. 12x5x12 5.5x8x12 Is my rear dimensions I have on either side. I can only use one of the two for each side if used.
Edit: I was thinking about this, See if I can squeeze http://4xspower.com/d975/ under the hood. And get http://4xspower.com/d5100/ in the back. And if I need it, a D1500R on the other side.
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Ok So far with my calculations, with a D975 up front, and 2 D5100's Ill be able to supply about 1500W off the batteries.With the 225A alt I will have, that wil do 3k itself. My car only has lights, no AC very old so I am going to assume it isn't going to take all that much form here. So from this I think the set up should do well with those 3 batts and alt. Am I correct?
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Your Welcome.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
  • Who's Online   1 Member, 0 Anonymous, 1014 Guests (See full list)
