2003 chevy cavalier "BIG 3 UPGRADE"
man does any one have the cuts i need for the big 3 in my car.....and have good instruction on to doing the whole process?!....im in dier need of know i need to get some more power fast!!
2007 JEEP COMPASSDC LEVEL 4 18"AUDIOQUE AQ 2000.1ELEMENTAL DESIGN NINE.4
:bow28:
piece of string, mark your lengths you need to cut. Alt + To battery pos, self explanitory. Alt - to battery negative, easiest is probably to just use the alternator mounting bolt. And chassis to batt negative, locate a nice body ground and go to batt negative
ummm....You should just have 1 positive from the big 3 to your battery.
Go from the positive on your battery to the output stud on your alternator.
From the negative on your battery to a good ground to the chassis.
From the negative on your battery to an alternator mounting bolt.
There are quite a few threads with nice writeups and pictures though, more helpful than any amount of words.
  • 1 month later...
If you get the wire I'll help you install it, it's pretty easy
Duel Sa-8 V.2 D2 Sub Enclosure
2001 Pontiac Grand am
  • Head Unit - OEM
  • Processor - RF 3sixty.2
  • Subs - RE Audio SXX12D4
  • Amplifier - Kicker ZX1000.1
  • Mids & Highs- Rockford Fosgate Power T2652-S
  • Rockford Fosgate Power T1693
  • Mids & Highs Amp - Rockford Fosgate Power T400-4
  • Wiring - 1/0 AWG, 4 AWG, 8 AWG
  • Alternator - Stock
  • Batteries - non ext
  • Box- Absolute PSEB12BK
  • Who's Online   1 Member, 0 Anonymous, 1045 Guests (See full list)
