My Electric to run 2.5K need help
Hello
I have Re XXX 18" about 2000 rms running through BRUTUS Hifonics at 1-ohm 2600 watt
this is my electric :
Mechman Alternator 200 amp
1 optima yellow top 55/ah in front
1 stock battery in the trunk
Big 3
all 1/0 gauge wiring
my next step is does the Voltage boost module will help me to prevent dropping voltage? anybody recommend it for me?
how much Optima battery i need to stable my voltage as most i can , btw we have only optima in my country,,
any suggestions?
a voltage booster wont really help you with losing voltage. someone correct me if im wrong, but if you drop to like 12v, adding a booster will still have your voltage drop because the alt cant output enough power.
how low is your voltage dropping?
Really!!
i have drop at full tilt to 12.8 almost after installing the new alternator , do i need more battery to reserve some capacity ?
some times my voltage start 14.2 but why i see people start with 15.3 for example i want to reach that level
i don't want to drop my voltage to 12 anymore is that hard to achieve , i have only one 18"
Replace ur stock battery with a good xs power batt and that will help alot
2000 stratus10 SunDown E-10s
Singer 250amp Alt
Xs Power D975Concept c2400All 0 gauge wire10 6 1/2's in Rear Doors
Not all cars run at the same voltage.Usually it sits around 14.4v , but it can be lower. In my toyota it 's at 13.6-1.38 v from stock.
You should not drop so low with a Mechman alt, 2 batts and 2000 w rms. Check all your grounds. Try to charge your batteries.
What VC config on your sub ?
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
That's what i will do , but am from Saudi Arabia we have only Optima , it's hard to ship Xs battery to heavy will cost more , it will be more cheaper if i get my optima 75a/h
I will try to make that movement , what do you mean by VC config my sub is Dual 2-ohm wired to 1-ohm
If you can get a mechman alt, you can get a XS battery lol.
i don't know if it's allowed to ship a huge battery to Saudi Arabia that's so bad , but Optima it will get the job done i think
  • Who's Online   0 Members, 0 Anonymous, 1332 Guests (See full list)
