wwjm Posted March 24, 2012 Report Posted March 24, 2012 Picture this 2 rf t2500.1bdcp's 4 12" havocs 1amp per 2 subs what would be the better way to wire these either wire 2 subs down to 1ohm load to 1 amp or strap the amps and wire all four to a 1ohm load will there be a difference in performance 1 way vs the other??? whats best solution for this issue? and do i really need a bass knob or run off the hu???? havocs 1250rms dual 1ohm subs hu pioneer avh440bh(8 band eq settings) rf bld line driver 3sixty 2 channel(for the lows)
varietyguy Posted March 24, 2012 Report Posted March 24, 2012 It's either run 2 subs to 1 amp a t a 1 ohm load or run the amps strapped @ 2 ohm. Strapped would be more efficient. 1992 Mazda 323 http://www.stevemead...323-wall-build/
wwjm Posted March 24, 2012 Author Report Posted March 24, 2012 it'll be more efficient because u dont have to dial them in you can just adjust one amp and its done well if something happens to one amp is it going to do the same to the slave amp???
