2 12" obsidian d2 box help
Spl-Zx2
So I'm building another box for my obsidians and I want to experiment a little.I've seen a lot of vids of people facing port and subs forward and I want to try that.I've also seen some facing the side of the trunk.I'd like to know which would be better for daily use and getting low.the car is an 03 escort and the amp is a crescendo bc2000d @ .5 ohm.
Sub/port front firing or back firing is usually the best for that type of vehicle you have to try both and see which you like better, Also that amp can smoke those subs, You must know what you are doing, in any case it wont't hurt to engage the subsonic filter.
I'll probably try sealing it off last.the only reason I'm skeptical of it is because I turned the subs around firing into the cabin and pushed the box all the way to the back of the trunk(with ths seats down)and it sounded horrible.anD I have the subs @ 2 ohms on the amp right now and they kinda move but not really
If I wanted to go low and loud I would get a couple of 12" SSA XCONs which are 1700W RMS each and are great SQ subs,
  • Who's Online   0 Members, 0 Anonymous, 672 Guests (See full list)
