So I've had the Alpine MRP M1000(1000 rms) paired with 2 12" Kenwood w3013ps (400 rms each) for about 8 months without a problem, but 3 days ago something happened and the amp is not working anymore. It all started while i was driving when the volume of my subs kept going up and down while no one was touching the volume on my deck or amp(placed in the trunk). Next day amp was doing the same thing, but after a stop somewhere I got back in my car, I heard the subwoofers make a faint noise then they stopped working. I checked all the wiring and fuses and everything is fine. The amp light is on but the subwoofers don't move. I tested the subwoofers with another amp and they work perfectly. Anyone have a clue on why my amp is still on but doesn't send any power to my subwoofers and what I can do to fix it? Thank you in advance.
I had problems with my alpine 1000. Was the amp warm? I know they have a builtnin feature where if it gets hot the amp turns it self down automatically. Thermal protect. As for not working maybe something could be broken . Mine would always get quieter then normalnthen quieter, finally i sold it.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Use ddm and check AC voltage from speaker outputs.. If there is any
The amp has always been warm to the touch regardless it being underneath my passenger seat or in the trunk. Noob question: What setting should i have the volt meter on and what numbers should I be looking for?
ac volts
90 honda civic lx 4 door
sony cd head unit
mmats mp5 eq/crossover/line driver
35 farad hybred cap
ppi sedona 430ix on mids/highs
hifonics brutus brz1700.1d @2 ohm 1200w rms
front/jl audio evo 6.5 components
rear/kove audio 2 way 5.25
subs/pioneer premier tsw3002spl 12x2 1000wrms ea 3000w peak
and a hi amp alt 160a
http://www.stevemead...0s-honda-civic/
