Sub pops when i play it at low volume.....need help
already tried that....the amp is fine, the ground is also fine....
got a quick check just to make sure....one of the tinsel leads are separated from the spider....and it makes the slapping noise...didnt see it before cause it was dark.....
could it be possible that it happened when i tested my new dd M4??bass gain was at 0 all the time....well....maybe at 1 for 10-20seconds....
Edited by gally
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
checkced again....one of the tinsel leads is cut off.... so its a total mess....thanks for help--can this thread be closed??
i had a popping issue like that once, my issue was that i had mounted a little 2000watt mono block amp to the speaker box vertically for my 2-10's i was pushing them full tilt, until one day the amp crapped out on me, resolving in me putting the amp horizontally(lol), and after a month of banging again the amp finally gave out. But back to the popping, no idea why my subs actaully did that maybe it was because of the amp maybe just bad wiring, it would pop like you said in the beggining when raising volume or in the middle of raising it up to the max volume i could go to. It was never an issue for me to look back at because i had a back up amp, so i just chucked the other one in the garbage.
build coming late April, early May
build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/
1997 Dodge Ram 1500 Slt Laramie
Amplifier - AQ3500d.1
Sub - DC LVL 5 18"
Highs - (2x) Selenium ST-350 Super Tweeters 8ohm
Mids - Selenium 6" 200w midrange 6W4P (pair)
Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch
Wiring - XP Flex 25' Red, 25' Black
Alternator - Mechman 270amp
Battery - XS power D3100, 1- Yellow top front
more to come...
update comin in about 5 minutes....i finally got the camera and to show you the weird popping noise....
is it possible to get that violent pop from just a cut tinsel lead??
any help?
please i would like to get rid of this problem....
one of the tinsel leads is cut off and the other 3 are just fine......
so...time for a recone??
had this issue once with a sub. the joint where the coil and spiders were glued together broke, ripped a tensel lead and sounded EXACTLY like yours does. have u checked to make sure the spider and coil are still together
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
  • Who's Online   1 Member, 0 Anonymous, 1137 Guests (See full list)
