So i currently have a Re audio SE10˝in my trunk which is being powered by an Alpine Mrp M1000, at 2 ohm (sub is D4 wired down to 2 ohms)
The sub is packed in a sealed box, and there is no air leaking between the sub or the box (checked that first).
my connections are also good,
the weird thing starts when i start playing some music at low volumes and the Sub starts with a popping noise
could it be possibly that one of the tinsel leads slaps?
or is there any other problem?
i will upload a video of the sub popping tomorrow when i get the chance...
thanks in advance
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
any help??
weird...try taking the sub out and playing it at volume that would normally cause the popping. see if it causes it then. if it does you could probably pinpoint it a little better where its coming from
I had 2 - RE sex 12 dvc 4's that did the same thing, mine was tinsel slap,,,, now i wont own a sub that doesn't have sewn in tinsels.........
  • Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO
Pioneer DEH-3400-UB
Vega 65 cs & 1" tweets & T3 4" coax in Front
1- Dual 300 with an AQ sticker
2-AQ sdc2.5 12's
1- AQ 1200D.1
Monster Cable RCA's
Monster Cable 4-awg
Custom 4 th order box ( by DBC )
Crescendo FT1's in rear- 1/0 Big Three
Opti Blue top in back for Mono Amp
Stinger Power dis. block
125 amp breaker at front batt.
Stock Alt.
mine is the older model of the SE series....i had that sub for over 2 years(+2years in garage) and it banged...
checked the sub and the tinsel leads are fine........dont know what is it...but when i play the sub without the box it still pops..
Signal issue from the HU? Try different RCAa yet? How's the ground on the HU?
no issue with the HU and already tried the RCAs
the surround and the spiders are fine
woudnt know what is it....
video comin up tomorrow.....gonna check the sub again...
Try a different sub. Then you'll know whether it's the sub or the amp.
I've seen it happen when people have had their subs wired ridiculously low, or the amp isn't getting good voltage. Try grounding it in a different spot.
If it is an actual popping noise try to look at the coil if you can. You may have 'slinky'd' it and it is shorting out on itself.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
