ChrisL Posted March 26, 2012 Report Posted March 26, 2012 Yesterday when re-positioning my sub box, i had to disconnect my ground wire and remote turn on wire and the battery. When i reconnected the wires and my battery and started up my car, the bass wasn't nearly as loud.. Any ideas as to what may have happened? I checked all wires going into the amp to ensure a good connection.
Trey_Dog650 Posted March 26, 2012 Report Posted March 26, 2012 maybe its cuz you repositioned the box? 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
ChrisL Posted March 26, 2012 Author Report Posted March 26, 2012 maybe its cuz you repositioned the box? ehh i don't think so. the box is in the same spot. i had to move the box b/c of a spare tire.
Guest Posted March 26, 2012 Report Posted March 26, 2012 cause you repositioned it lol. acoustics are a bitch and you just experienced that first hand.
bang'in in ga. Posted March 26, 2012 Report Posted March 26, 2012 Open up th box and check wires on subs, if u hav'nt already............... Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO Pioneer DEH-3400-UB Vega 65 cs & 1" tweets & T3 4" coax in Front 1- Dual 300 with an AQ sticker 2-AQ sdc2.5 12's 1- AQ 1200D.1 Monster Cable RCA's Monster Cable 4-awg Custom 4 th order box ( by DBC ) Crescendo FT1's in rear- 1/0 Big Three Opti Blue top in back for Mono Amp Stinger Power dis. block 125 amp breaker at front batt. Stock Alt.
ChrisL Posted March 26, 2012 Author Report Posted March 26, 2012 cause you repositioned it lol. acoustics are a bitch and you just experienced that first hand. will a 1 inch lift on the bottom make that big of a difference? I added a spare piece of mdf under my box to act as a floor for my box. the difference is fairly dramatic
Guest Posted March 26, 2012 Report Posted March 26, 2012 if its as bad as you say it is, i would see if maybe a wire came loose inside the box like bang'in said. if its all facing the same way as before, the difference (if even) would be minute.
ChrisL Posted March 26, 2012 Author Report Posted March 26, 2012 thanks guys.. i will try that. that may be a possibility b/c my wires are run through my port and i had to keep manuevering the box
