this is my old system, just sold it and got myself a hsv R8
its all kicker
started out as a simple build
Head unit
Eclipse AVN6000
Front surround (coaxial mounted +6db to tweeter)
Kicker QS65.2 @ 75rms ea
Rear surround (coaxial mounted +6db to tweeter)
front/rear surround amp
Kicker ZX700.5
Sub amp
Kicker ZX400.1
Kicker Zx700.5 (same as surround)
Subs
2x Kicker cvt8.4 @ 210rms ea
Kicker cvt12.2 @ 400rms
all the doors are dynamated inside and around speaker
+floor and rear wall
car '09' sr5 Toyota hilux d4d
custom leather,twin sunroofs, alloy bar, hardtop, tub liner, etc
head unit eclipse anv6000
rear surrounds with dynamat
rear subs before amps mounted and backseat refitted
up front is kicker 0/1 wire from battery to amps
0/1 ground goes to distribution block then 0/1 to engine block, also from block is 3x 4gauge cables to factory bolts on body/rails and ecu
A few options i look at for amps and crossovers
only problem was 4 crossovers and only 3 fitted
so i had to fit them in the doors, amps stayed where they were
done some add-on about 3 months after finished install
added another amp and changed components to actice
The crossovers had this as an option
So a added another Kicker ZX650.4
But unfortunately I'd have any picks of amps on back bored for first install and any of addishnal amp install
All I did was stack the 650.4 ontop of 700.5 as there were the same size amp
Edited by john253a
