Sethorama Posted April 2, 2012 Report Posted April 2, 2012 Running 2 AQ 1200's strapped. so 2400rms to 2 AQ HDC3-15's. Running some KnuKonceptz 1/0 "CCA" wire. Also did my big 3 in the same wire. Should i change that lol? I honestly didnt know the difference between CCA and OFC when i ordered it. Am i okay with my setup or should i reorder for some OFC? Also is 1 run good enough or should i add another . Should i keep my dist block fused at the amp end? or can i run it w/o one?
matt14 Posted April 2, 2012 Report Posted April 2, 2012 Ditch the CCA and pick up some OFC. Personally, i would also ditch the distribution block and run 2 power wires to each amp. 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Loslam Posted April 4, 2012 Report Posted April 4, 2012 4 runs 1/0's total, 2 per amp, 1 to positive 1 to negative of each from positive and negative of battery. Use a 1/0 to 4 gauge wire reducer to fit the 1200 inputs Something like: http://www.amazon.co...ries/B001H1MF18 Overkill is never a bad thing in electrical 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/
