vamps123 Posted April 4, 2012 Report Posted April 4, 2012 ok so i bought my DD-1 and i set everything on my headunit to flat, did the headunit then set my gains on my mid and high amp. but my question is after i get done can i go back into my headunit settings and set the Low/Mid/High setting to what i want them at? they range all from -10dB/+10dB i had the Low at +5dB and the mid at +3dB and the high at +3 dB. so i guess my question is can i go back and change that back to the way i had it or do i have to listen to my music on flat? its sounds kinda bland with everything on 0dB Thanks
ant the ninja Posted April 4, 2012 Report Posted April 4, 2012 I've also wondered this too. But if you put your low up there's a good chance you'll clip your subs 2002 Ford Explorer XLT Front Stage: Crescendo CCX 6.5's Rear Stage: ??? Two 15" Powerbass M154 Audiopipe AP15001d Pioneer DEH-P5100UB
vamps123 Posted April 4, 2012 Author Report Posted April 4, 2012 Sorry i have no subs its just the mids and highs right now
MrSkippyJ Posted April 4, 2012 Report Posted April 4, 2012 Better to adjust them down from whatever point you had them set when you used the DD-1 F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
