BillKessel Posted April 5, 2012 Report Posted April 5, 2012 Alright so im trying to make decent circle's for the subs people are saying buy a plunge router.... i went to home depot and i seen one for 99 dollars....... in between the two suspension isn't 12 inches apart so my question is, do you buy a large diameter attachment and then attach or what, the box wasnt very descriptive for a noob!
tejarillo Posted April 5, 2012 Report Posted April 5, 2012 Just buy a jasper cutting circle jig look it up in amazon it should be around 30-40 bucks
BillKessel Posted April 5, 2012 Author Report Posted April 5, 2012 Just buy a jasper cutting circle jig look it up in amazon it should be around 30-40 bucks Will that fit any plunge router?
tejarillo Posted April 5, 2012 Report Posted April 5, 2012 Check the site it says what model and brand it will fit
jrchevy87 Posted April 6, 2012 Report Posted April 6, 2012 if your good at measuring and on a budget you can make a circle jig out of a thin piece of wood, but if you got the money to spend get the jig it deffinately saves time and saves you from screwing up from measuring wrong (im guilty of that one lol, measured to the inside of bit instead of outside and holes ended up 1.5 bigger than i needed) Jeep Wrangler TJ Hardtop Build
CleanSierra Posted April 6, 2012 Report Posted April 6, 2012 Get a decent brand plunge router like a Bosch. The things spin at crazy high RPMs so if when you go cheap, you run the risk of getting one with a cheap motor, which may burn up on you. Im not the one you want to try to troll. Just a fyi for you.
