Sheena Posted April 6, 2012 Report Share Posted April 6, 2012 few things to look at, for one, check the ohm load exactly, its one of those things that actually matter in this situation. for two, dont measure the voltage on the dash, its rather in accurate and does not measure the amps voltage, which is actually lower than the voltage at the front of the vehicle. third, make sure the amp can breathe, if its closed off from circulating air its going to have a hard time cooling off. Quote 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop Link to comment Share on other sites More sharing options...
evermaxx Posted April 6, 2012 Author Report Share Posted April 6, 2012 Went to autozone, bat and alt checked good. Quote Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 7, 2012 Report Share Posted April 7, 2012 They don't really check them. Do you have a multi meter? Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
evermaxx Posted April 8, 2012 Author Report Share Posted April 8, 2012 Found out what it really was I belive. Ohm load But still doesn't make sense that it would only protect when car was on. Quote Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
vibrator Posted April 8, 2012 Report Share Posted April 8, 2012 it might be because more current changes the ohm load. Quote Henry Ford once received a letter from a depression-era bank robber responsible for the deaths of several law enforcement officers, killed in their attempt to stop him as he fled the crime scene. In his letter, he thanked Mr. Ford for making his Model A Ford such a good getaway car. Link to comment Share on other sites More sharing options...
Sheena Posted April 8, 2012 Report Share Posted April 8, 2012 It's probably cause the amp is seeing like 10 volts with the car off. I'm not sure on technically why that matters, but 10 volts is never good Quote 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop Link to comment Share on other sites More sharing options...
