So I picked up a batt from a friend, HC1800 it's resting at 12.75 is that a good voltage to install at or should I charge it prior to install?
I will be using circuit breakers on each end and grounding kinetik in trunk.
Any info would help.
Also mods if I'm posting in the wrong area feel free to remove, I couldn't find a suitable area for my question.
Under Construction
2011 Malibu 1LT
12k DDM Tuning HID's 55W
Soundstream 6.5 components(front)
Inffinitty Kappa 6x9's (rear)
I suggest charging all batteries before installation
Fuse on the positive coming off the front to the rear battery as close to the front as possible
Fuse the positing going into the rear battery coming off the front battery as close to the rear as possible
  • Who's Online   0 Members, 0 Anonymous, 1154 Guests (See full list)
