fidmh Posted April 7, 2012 Report Posted April 7, 2012 I've spent the last 2 days trying to figure out my best options in regards to aeroport for my box and I just can't figure out what to do. I am running a single nightshade v2 18" on a Crescendo BC3500 and want the box to be 4 cubes after all displacement & bracing at 30hz. The dimensions of the box are roughly Height - 18 Width - 30 Depth - 18. I was thinking 1 6" aeroport at 16" long or 2 4" aeroports at 14". The main problem I am having is getting the most port area I possibly can because it says I am below the range on the Torres Calculator. The setup is going to be Sub up and port back in a trunk car. I've thought about all the different possibilities such as; elbows inside the box, elbows coming out the side of the box to face the rear but neither of those options interest me really unless they are my only option. I understand a few people might say just go with a slot port but I haven't yet created one and would just like to stick to aeroport at this time. I'm sure sometime in the future I will make the conversion but as of now I'm just going to stick to aero's. My last question is when using the Torres calculator and finding the length of a port does it already include the flare length of port or do you need to add 1 inch to what it says? I would greatly appreciate any help I could get regarding the issues I have posted above. Thanks in advance
Joe X Posted April 7, 2012 Report Posted April 7, 2012 Ok your tuning is real low hope you are clear what you want to accomplish with it. Here is what came up with: Enclosure Specifications: Fb = 30.072 Hz Vb = 4.035 ft^3 External Height = 19.5 in External Width = 29.75 in External Depth = 20 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 29 3/4 x 20 Left & Right Sides = 18 1/2 x 17 1/4 Front & Back = 29 3/4 x 17 1/4 Port Quantity and Dimensions: Number of Ports = 1 Pipe Port Diameter = 8 Pipe Port Length = 31 1/4 Obviously the port has to turn with an elbow and will need bracing. See if the dims are suitable.
