JL Amps and fuses
Now someone told me my ground wire should be bigger than my power wire?? is this ture??
is OFC=oxygen free copper or no??
it can be larger just not smaller. the same size is ok. so if you are running 4 gauge OFC power you will want 4 gauge OFC ground
yes OFC = oxygen free copper.
just some advice, go with this http://www.knukonceptz.com/productDetail.cfm?prodID=KFX4BL
that is some good wire for the price.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
no probs man get some pics and vids up of system when your done. ive always liked JL audio highs and bass. i used to have a JL J2 500.1 before my current setup and i couldnt be happier with size and fidelity of my JL 400/4
BMW M340 xDrive
yes. if you go CCA go with 0 gauge for your main run. OFC can carry more current. if you only get CCA 4 gauge you will only be able to carry 100Amps max-120A the OFC can most likely carry up to 150A maybe a little less. i havnt done actual testing. if you go CCA go 0 gauge. if you go OFC you can get away with 4 gauge
BMW M340 xDrive
  • Who's Online   1 Member, 0 Anonymous, 1586 Guests (See full list)
