scooter99 Posted July 2, 2012 Author Report Posted July 2, 2012 Here's some updates. I didn't get as much done as I wanted to, but when does that ever happen!? Right!? But I wanted to get this whole thing done and ready to be installed in the truck this week, leaving only the rca's, ground, power, remote, and speaker wires to be ran, and the head unit to be swapped and do that on Wednesday, I'm off for the 4th holiday. But I'm not so sure that's gonna happen. I had a crazy busy weekend and the time that I thought maybe I could squeeze in a couple more hours last night but what we thought was going to be a couple hour day turned into a full day. Didn't get home till 11:30 last night. Today we traveled again! But, here's what I did get done! I started Friday night since I got off early and my wife had the kids. I did have the dogs and they needed some play time as well as I needed some work time. So I drug everything out back from the side of the house and decided I'd do two things at once. It was pretty warm so I got my mister fan I made, and my misters going on the patio. Now that comfort was achieved, it was time to get busy! I decided to get started with the amps! I was only going to run the 1.2500D but I decided that the 4.500 would do well in the cabin. It would also give me some more power to my speaker boxes I made for outside. So I started laying those out! 4.500 1.2500D Fuse holder that came with it. I decided to center the amps off the subs and the logo. They actually flow pretty well I think. Now using the same threaded inserts, I mounted them up. Now that the amps were mounted and ready to go, it was time to get busy on the subs. Got out the hardware I needed and bought last week, so I could get those wired up. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted July 2, 2012 Author Report Posted July 2, 2012 God wouldn't this look so sexy! If I only had the room to do this! So I got to wiring them up! Positive to negative from one coil to the next! Then positive and negative out. I found these the other day when getting my hardware, and thought they'd be perfect for this. So I picked them up. One for positive, and one for negative. Now let's get em attached. I used some washers with rubber attached to them. This was on the inside and out, to help seal it up. Then I got my pig tail made for the amp. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted July 2, 2012 Author Report Posted July 2, 2012 Subs ready to go in. Running out of light as you can see! Then I kind of panicked when I got these readings. I thought I had dual 4ohm subs, and would get a 4 ohm reading out of this. Turns out I had dual 2ohm subs and that's why I'm getting a 1.8ohm load. After that light was really pretty much gone. I started to wire up the amps and got about as far as I could until I could see much anymore, even with the porch light. I got the fuse block in, the power wire ran to each amp, and then a bolt for the ground in, and the ground wires to each amp. Also ran the sub pig tail wires. These were from Friday night. Kind of dark, and not the greatest pics. Then I decided to get a couple more today to see a little better. Sexy subs Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted July 2, 2012 Author Report Posted July 2, 2012 And a little wiring. I used wiring I have here. I didn't want to bust into the new stuff just yet. SO that's why it looks a little miss matched. Like I said before I have to run the remote wires, the speaker wires, the rca's, power and ground wires and then the head unit swap. Then she should be playing. I am also thinking I may do a quick trim panel to hide all the wires up. Not sure on a color just yet, but I will most likely do black since the amps will give it some color itself. So, for now, that's it. Hopefully I'll get some more done this week. Thanks for checking it out. As always, please visit my build log which is linked in my signature to comment on these pics, as well as hear and / or participate in all the behind the scenes chatter. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted July 5, 2012 Author Report Posted July 5, 2012 Ok so I didn't get a ton done yesterday or Tuesday night, but I was able to get some done and be a bit happier with the project. What did I do you may be asking. Well I basically stripped it out and rewired it. Considering this is my only project now, there's no sense in trying to miss match all the wiring and wire with scraps. Most of the main wiring will stay, with exception of the few short runs on the amp rack itself. So I started doing that Tuesday night and got mostly done by last night. Didn't have all day yesterday to work on it as I wanted to, but I had a few hours and I used that time the best as I could. Let's get started. First thing I did was start getting the head unit out of the truck and get ready for the new one to go in. Here's the old Pioneer unit. This one sux cause the RCA's don't work on it, specifically the subs rcas. So it's gone! Now it's time to make way for this beauty! Got my tools out Got to work! Wires all stripped and ready to get the business! Heatshrink, and a connector for the remote wire. First two sets tinned. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted July 5, 2012 Author Report Posted July 5, 2012 Head unit wires tinned and the connector soldered on. Heatshrink on and waiting, and harness ready to get connected together. Time for shrinkage! All together, time to clean her up! Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted July 5, 2012 Author Report Posted July 5, 2012 Cleaned up and ready for installation. So then I moved onto the amp rack. Recall that it looked like this last time I showed it. Well that all came off. To make room for the new stuff! Stinger HPM Wire! Mmmmmmm yummy! I have one more 1/0 ga silver spool I don't have pictured. That's what I'm using for positive. So instead of using those screw on things, I decided to use the solder on, or crimp on, terminals. Problem was, I don't have any 4ga terminals. SO I had to crimp down a 1/0ga terminal to fit. Not the purdiest job, but it'll do for now. I don't think I have the right solder. But I'll be addressing all that before the rest of the build. So I got a little carried away with working, and forgot to take pics of the work in progress as far as soldering wires etc. But they're all protected with heat shrink, and terminal soldered and ready to go. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted July 5, 2012 Author Report Posted July 5, 2012 Ok I'm back. More pics! Heatshrink on the terminations! This is the 4ga, and the heat shrink I had was too big, but it will work. I need to re up my inventory of shrink! 1/0 ga. Stinger Blue Translucent remote wire! Soooo nice looking and feeling! Need to do some cleaning up, but it's coming along! Decided I needed a relay for the remote wire. So I grabbed the rest of the translucent wire and some stinger red wire, and ran them with the RCA's. Time to bundle up! Wires snaking down the hall! My little helpers Getting it all put together! Slowly! Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted July 5, 2012 Author Report Posted July 5, 2012 So again, I ran out of light cause I was working and not taking pics. But I got the RCA's placed, the volume knob wire place, and the red and blue wires placed. Started getting some zip tie bases on and tidying things up. As you can see it was getting dark out so I had to stop here, clean up, and get things set up for fireworks! Here's the rest of the pics. Even in the dark you can see how much cleaner things look. But I'll get some better ones tonight when I get home. Or it'll wait till tomorrow night when I can work on it again. REally need some shop lights on the side of the house. Bundle of RCA's and wires to go to the front. Here's what's left for wiring. So I have that little bit left for wiring. I also need to make a trim panel to go over it and just show the front of the amps. That shouldn't take long to do. Still have to run the power and ground cables from front to back of the truck, get the rca bundle ran, and put the head unit in. Then, it's time to tune with the good ol DD-1 and see what she sounds like! Getting there. POSSIBLE, it'll be up and playing by Saturday night! As always, any comments, suggestions, or just to see what's going on behind the scenes, check out my build log which is linked in my signature. Thanks for checking in! Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted July 6, 2012 Author Report Posted July 6, 2012 Nothing new guys, just some day light pics for you! Should have more updates tomorrow night! Facebook Page: S99Creations 2006 F250 Lariat Build
