i want to build a box for my old pioneer ts-w2000spl
12" speaker
displacement is 0.083 cubic feet
these are the numbers i have to play with
tuned to 32-35Hz
pioneer says for ported enclosure 1.75cf
cut sheet and diagram would be nice.
amp is sax-1200d or saz-1000d
14"height
32"width
16"depth
thank you
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
Ok this is done on Pioneer specs (checked the data you provided) , your amps can really cook that sub, set your subsonic filter to 30Hz to help protect it.
Enclosure Specifications:
Fb = 34 Hz
Vb = 1.741 ft^3
External Height = 14 in
External Width = 26.25 in
External Depth = 15 in
Port Width = 2 1/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 26 1/4 x 14
Left & Right Sides = 13 1/2 x 12 1/2
Top & Bottom = 26 1/4 x 13 1/2
L Port Internal Assembly Parts:
Front to Back = 11 3/8 x 12 1/2
Extension = 15 x 12 1/2
Assembly guide:
If you want anything changed let me know.
as long as i match the gain to the sub i should be good correct.
Edited by ham4864
2009 bmw 5 series
Head Unit Stock
looks good but what about a design like this see how every think sits on the bottom and the front,back,port and sides are the same height.
i'm not that good with sketchup.
Edited by ham4864
2009 bmw 5 series
Head Unit Stock
That's because the sub cutout on a 12.5" baffle would leave a clearance of 0.75 each side, can be done but an all across baffle is stronger and easier to cut but if you are not bothered by this here is the alternative assembly:
Fb = 34 Hz
Vb = 1.741 ft^3
Cut Sheet List:
Front = 23 3/8 x 12 1/2
Back = 26 1/4 x 12 1/2
Left & Right Sides:
Side 1 = 13 1/2 x 12 1/2
Side 2 = 14 1/4 x 12 1/2
Top & Bottom = 26 1/4 x 15
The figure matches the one you posted.
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
