ANYBODY WITH A 98+ CROWN VIC OR GRAND MARQUIS, WILL THIS FIT?
^^^ Lots of good info here^^ any pics of your setup bro?
and okay so when you say
switch the - and + going from the amp into the subs this makes the sub "pull" in on the first stroke which is towards the inside of the cabin
i can run 1 15 to one of my zx1000s at 2ohms and basically on the AMP side of the wire switch the + and - so that it it goes in reverse? correct? and DONT switch the 2ohm wiring job up? leave that the same? just switch the + and - on amplifier?
another question, im lookin for some 6x8s since all four spots are 6x8 and im curious on finding/comparing some that are cheap but still good.. im thinking the ks68? ill run all 4 of them to my zx650.4 and on mid filter.. how are the alpine type r 6x8s? even though there like $40 more for a set.. ive heard good things about kappa.. i am NOT trying to spend over $200 on all four.... so please only suggest ones in my price range lol.
just ordered a clarion eqs746, my question is, im gonna have my 2 zx1000.1s, one on each sub my zx650.4 and a zx200.4 on my highs should i run my sub out on my jensen uv10 head unit to the amps or should i do it off the clarion equalizer? basically whichever one i run it off it will need to be controled by that obviously
and do i run my rear rca output on my uv10 to the equalizer and not my sub output or front correct? im gonna have my zx200 on my front output on the equalizer and my zx650 on the rear output?
DOES THAT ALL SOUND ABOUT RIGHT??? the only reason i have the equalizer is because my headunit only has a 3 band equilizer..
what are some good rcas that i should order since i need like 6 pair lmao are the gold plated ones best?
ok got on the comp wrote a great response and fucking computer hit back and i lost it all... ok here we go.... again
about the push and pull or phase
the ohms will not change switching + and - at the amp, but the first stoke of the sub will be in, so in the box you designed that would work perfect with the first stroke when the subs are mounted facing down will but up.... you can also do this buy changing the phase on the amp OR headunit to 180 degrees i think that was is easier because you dont actually have to switch the wires on the amp.....
so in all you would only use that inverse mount in a 4tth order like that not in a normal ported box
next your question about the speakers
i beleive they are 5x7 holes and many companies makes speakers that size i used the kicker coaxials for a while, then i stepped my game up and got beymas, now all thats going to my mustang for my SQL setup and ive moved onto 14 focals 6.5s and 4 hertz tweeters, i think that im going to do super tweeters instead tho
i would look into parts express and buy the t3 speaker buyout can go wrong for 30- 40 a pair and you can get the round 6.5s or 5.5s and they will fit! (i just like round speakers way more im completely against the oval or square)
im completely confused on your last part tho about the rcas
keep it simple there man, for instance i have one rca with 4 jacks for the mids and highs going to a crossover then into the amps and i just used y spillters attached to the amps so it takes 2 and makes them 4 that way my front 2 channels are 4 rca outputs in the end at my high amps and my 2 rear ouputs comming from the front end at the mid amp's y splitters and takes thoes 2 and makes them 4
then my sub rca goes straight to rear amp and i use the crossover from the deck to make sure the sub play what i want too
and link to buildlog
http://www.stevemead...__fromsearch__1
so you have 2 amps running your mids and 2 on your highs??
should i even use crossovers on my tweeters if they are going to be on high frequency on my amp?? also, what frequency crossover would work BEST? like what khz. i figured my clarion equilizer would take care of the crossovers part? or should i do both so i know im getting true highs and true mids..?
crescendo super tweets.
cheap tweeters sound like cheap tweeters. you have to spend at least SOME money if you want something that sounds decent.
are you referring to the xst2? there only $19.99 each??? are you saying there good or just cheap junk?
One amp on the tweeters one amp on the mids
Loud and cheap I would go crecendo supertweeters
sometimes more tweeters doesn't always mean louder, I only have 4 tweeters and have 10,000 rms..... 14 6.5s for mids/midbass
and when I had my single beyma components they kept up no problems wit the subs and that's 2 6.5s and 2 tweeters on about 75 rms each side (1 mid and 1 tweeter per 75 rms)
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
U would be better off gettin a really good set of comps rather than a crapload of cheapones
Im crossed over at 80 ish on the subs 80 to 3500 on the mids and 3500 and up (20k) on my highs the tweeters
SCSB
Build logs:
so a 20k and up crossover for tweeters, 3.5k for mids and 80hz for bass? got any links to some? would i need them though with my equilizer? or should get some to be safe and make sure everything lasts a long time
whats the differnce in coaxal or w.e and comps. are coax ones that are not circle? lmao idk can i run some 6.5s as highs with a 20k crossover? or keep them as mids?
Ur tweeeters are 3500 and up
Mids are from 80 hz to 3500 where the tweeters pick up
Subs are 80 hz and down
I was gonna go to the new crecendo the copper colored ones 4 ohm give them 75 rms ish, supertweeters are VERY efficent
All I ask is you post a pic of your engine bay, I need to see where your coolent resivior is
Thanks
SCSB
Build logs:
  • Who's Online   0 Members, 0 Anonymous, 1104 Guests (See full list)
