soundstream15 Posted April 14, 2012 Report Share Posted April 14, 2012 i been researching xs power and i hered nothing but good things, i currently have the kinetik hc1200, my volts are dropping to 13.2 now i do have a after market 105amp alt and all 1/0g and optima yellow top under the hood, its grounded fine, its grounded to the chassis its by the seat belt bolt i made a new ground..sanded and shiny. but anyways if i get a xs power d1200 would i see a difference? i dont play without my car being on.. i figured the xs power battery is better and can supply my amp better Quote Link to comment Share on other sites More sharing options...
Nathan @ XSpower Posted April 16, 2012 Report Share Posted April 16, 2012 If you are only dropping to 13.2V, then you are dropping to battery voltage now. You will not see any higher voltage by changing out to the D1200, but you would see more instantaneous power. In the end you probably wouldn't notice a difference on a daily driver, so I would just wait till you start having issues with the battery. Quote Link to comment Share on other sites More sharing options...
