How To: ELD Bypass for Honda Civic/Accord/Fit
Found this info on an Accord forum, maybe it will help: There is still an ELD on the 2013-2014 Accords. However, it looks like the change for the 2013-2014 Accords is a LIN (Local Interconnect Network) controlled charging system.
The alternator voltage regulator has a LIN wire going to the PCM (the LIN wire is yellow on the 2013-14 Accords). The LIN wire allows the PCM to control voltage and load response control rate. The PCM can also read back information and status of the regulator and alternator through the LIN wire. The LIN provides control/diagnostic on the same wire.
There most likely is an IC chip in the regulator since there is the LIN wire.
  • 1 month later...
  • 1 month later...
  • 1 month later...
Thanks to you all who have contributed, as I have a friend who is experiencing problems after replaceing a battery and alternato, in a 2001 Odyssey. The problem is that the warning lights now flash on and off intermittently. Does anyone have an answer for this problem or do you think the ELD could be faulty? I have found all kinds of info on Civics, Elements and Fits, but not the Odyssey. Seems like three of the vehicles can replace just the EDL if faulty, but the Odyssey needs to replace the whole fuse box.
Thanks for any help!
  • 1 month later...
  • 5 months later...
still wondering on the '13 accord ordeal......
headunit: pioneer 1400DVDsub stage: FI Q 15 D2sub amp: VVME inno-d 1500
voice amp: VVME 4 channel 4080.2nd battery: Soundquest SQB2000 2nd batterywiring:run of stinger ofc 4 gauge to 2nd battery
sky high and knu 0 gauge to bass ampsub box: custom ported box, 3.73^3 tuned to 32hz
rca's: stinger 6000 for basskicker 4 channel for voice
front stage:JBL gto608crear stage:renegade 6.2c
  • Who's Online   0 Members, 0 Anonymous, 2756 Guests (See full list)
