bigmescan Posted July 4, 2012 Author Report Posted July 4, 2012 ive got maybe 4 inches...........but thats pulling all plastic interior pieces off...................so im thinking just making a ring.............. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
pa-pa-platypus Posted July 4, 2012 Report Posted July 4, 2012 yeah when i was thinkin full external i was figuring on you having more room.. i have my amp mounted to my box but thats really not an option here.... hmm i guess just try the ring and if it fails you can also plug the hole and port up.. gotta work with what ya got really This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
bigmescan Posted July 4, 2012 Author Report Posted July 4, 2012 yeah when i was thinkin full external i was figuring on you having more room.. i have my amp mounted to my box but thats really not an option here.... hmm i guess just try the ring and if it fails you can also plug the hole and port up.. gotta work with what ya got really i can mount amps to the box but thats not the look im going for.............but performance comes before looks.................but if i leave it like it is.....will this effect the subs if i dont add a ring and just run it like it is................................. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
pa-pa-platypus Posted July 4, 2012 Report Posted July 4, 2012 that front sup is likely going to unload with it that close to the sub...ur only option may be to point the port ^^ which is fine really is sounded good when i had a box like that..could always paint the aero port to match ur box/truck to make it look better This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
bigmescan Posted July 4, 2012 Author Report Posted July 4, 2012 that front sup is likely going to unload with it that close to the sub...ur only option may be to point the port ^^ which is fine really is sounded good when i had a box like that..could always paint the aero port to match ur box/truck to make it look better id have to rebuild the box..................and thats not something i want to do at the moment...................so maybe have the port hangin 3 inches outside of the box??????? SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
pa-pa-platypus Posted July 4, 2012 Report Posted July 4, 2012 if you make like 3 rings for the aeroport that will bring it out of the box like 2.25 inches it might work.. keeps the subs as far away from it as possible when mounting them and the aero..and see how it works.. it should be ok This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
bigmescan Posted July 4, 2012 Author Report Posted July 4, 2012 if you make like 3 rings for the aeroport that will bring it out of the box like 2.25 inches it might work.. keeps the subs as far away from it as possible when mounting them and the aero..and see how it works.. it should be ok okie dokie smokie SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
bigmescan Posted July 24, 2012 Author Report Posted July 24, 2012 test fitting the box gonna have to do trim work this is behind center console this is behind passenger seat....im gonna have to maybe get another inch from the wall this is where both amps and the other batt will sit.......... and i also plan on removing all trim panels and gonna try to smooth everything out...... hopefully sunday i will have box in and wired depending on weather. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
Nikitaaa Posted July 24, 2012 Report Posted July 24, 2012 Looks very good! We have similar systems except I think you have the v2's and I have the 1.5's. Sorry if I missed it but is that the cp model? 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
bigmescan Posted July 24, 2012 Author Report Posted July 24, 2012 I wish.....but that's the 400.4 and the rf1000.1bd I still have to install...I've got an Idea of how I will mount them and have the XSpower sitting right beside the amps........and the infinity's will be coming out as well.........just a lot of little stuff I need to take care of.....the big3 is what I'm having issues with at the moment..... SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
