Never2Loud Posted December 20, 2007 Report Posted December 20, 2007 Can someone tell how to run 3 batterys in my X. I got a hi-output alt. 1 battery up front and 2 in the rear. Do i need to put a fuse in between the 2 batterys in the rear? I going to fuse the alt, fuse the battery up front and fuse it again at the rear before the 2 batterys and will i have to fuse the 2 in the rear between each one? And do i ground the rear batterys together or by them self? I will run about 3000 watts max from mtx amps so do i need 3 batterys or can i get away with 1 up front and 1 in the rear? And do i need dual runs of 0'ga. wire or 1 run? thank guys
jasonw30 Posted December 20, 2007 Report Posted December 20, 2007 Can someone tell how to run 3 batterys in my X. I got a hi-output alt. 1 battery up front and 2 in the rear. Do i need to put a fuse in between the 2 batterys in the rear? I going to fuse the alt, fuse the battery up front and fuse it again at the rear before the 2 batterys and will i have to fuse the 2 in the rear between each one? And do i ground the rear batterys together or by them self? I will run about 3000 watts max from mtx amps so do i need 3 batterys or can i get away with 1 up front and 1 in the rear? And do i need dual runs of 0'ga. wire or 1 run? thank guys no you don't have to fuse inbetween the 2 rear batt's.1 before the batts and ever how many amps fuse before each amp.you can ground them together also..i would also ground them to the chassis.dual runs of wire would be better,but 1 would work.i hope this helps you...good luck. http://www.kinetikaudio.com/manuals/khccells.pdf 2002 nissan frontier crewcab eclipse cd2000 mb quart prem's fr&rear rf p4004
