Well, I'm gonna be starting to build my First box and I did the torres calculation and then i checked to see what each piece would actually be. I think i got it all right for my cutsheet.
Had to redo the Sketchup. i forgot to save it the first time i did it.
Edited by TygaTony
looks good to me man
edit: the calc part at least, i didn't check the cut sheet
Edited by Kranny
Alright. I did a sketchup to find the cut sheet dim's. But if the calculations look Good I should be placing my order for the E-15 tomorrow and heading to get the MDF on Wednesday
Ok so I checked your cutlist and I see at least something not ok, and that is the height of th port parts (need to be 15.5") since I won't go into drawing your parts I generated a cutlist based on the Torres screenshot, here's the result:
PORT LENGTH = 32"
Enclosure Specifications:
External Height = 17 in
External Width = 24 in
External Depth = 23 in
Port Width = 3 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 20 1/4 x 15 1/2
Back = 24 x 15 1/2
Left & Right Sides:
Side 1 = 21 1/2 x 15 1/2
Side 2 = 22 1/4 x 15 1/2
Top & Bottom = 24 x 23
L Port Internal Assembly Parts:
Front to Back = 18 1/2 x 15 1/2
Extension = 9 x 15 1/2
Assembly guide. (the dimensions are GENERIC please):
^^ I Caught the mistakes right when i saw your post.
But i Started the Box today! I have most of it done except for adding a little bit more of glue tomorrow.
I didn't have 90 Degree Clamps So I used what i had. But it looks like its coming out nice!
What should I use to Cover the Seams to make sure its sealed. Just more glue?
is the bottom of the 2nd bend of the port not flush with the first bend? i would hope you put some screws in to hold the glue instead of using clamps at the top of the edge.
i used silicon caulk for sealing edges.
I used a Nail gun for that. its just that my air compressor didn't have enough pressure at the first nail and I'm just using the clamp there to close it a little more. And i'll go pick some caulk up after school tomorrow. How long should the caulk sit to dry for?
Made my cut out trace!
And my E-15 came in today!
Question: Since I have to wait till later in the week for the shop i go to get 8ga wire. Would it be okay If i just ran my 12 Ga Through the port since I haven't drilled holes yet for Bolt Terminals i intend to use with the 8ga.
When I carpet the Box, My dad has some Fabric Adhesive that I can use. Is that okay to use? or should i just use some wood glue and spread it around?
fabric adhesive man! that thing will never come off and make sure it has no wrinkels first mistake i made when i did a box for the first time!
My build
http://www.stevemead...20#entry2018495
Car: 2003 Cadillac DTS
(1) Hifonics Brutus BRZ2400.1
(1)Hifonics Zrx600.4
(1) 1000 watt crunch amp
(1)200 watt boss amp
(2) Pyramid TW46
(4) Infinity Kappa 60.9cs
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
  • Who's Online   0 Members, 0 Anonymous, 4092 Guests (See full list)
