2 Sundown 2500s $515 Shipped Each
1. Product:
2 Sundown SAZ 2500s, I am the 2nd owner on both amps, one amp has a replaced capacitor (done by previous owner at amp medics).
2. Specs:
----RMS power, 2 ohm linkable/dual mono
5000W x 1CH
----RMS power, 1 ohm mono
2500W x 1CH
----RMS power, 2 ohm mono 1200W x 1CH
----RMS power, 4 ohm mono
600W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~6dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm <0.1%
Efficiency @ 4 ohm 86%
Fuse rating 250A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 512(L)mm
3. Description/Condition:
1 amp has the "lpf" adjuster plastic phillips head chipped but still functions fine , the other amp has a added screw mount, other than that no scratches on the faces, they are functioning well. Make sure if you do strap them that you don't use stinger or memphis rcas and that you have good grounds, they are picky amps (as jacob mentions) as i have had issues until doing some troubleshooting. They function fine running them individually at 2 ohms and 1 ohm each.
4. Price: :
$515 shipped each, do paypal "Money Owed". Trades ONLY for a sundown 4500, or a Cactus K5 as i would like to run one at .5 ohms daily.
5. Pictures:
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
bump!!!
Team gg.
Can you do 515 shipped to Canada?
1995 Nissan Maxima GLE
JVC KD-APD49 Headunit
(4) Infinity Kappa 652.9i components @ 2 ohm
(1) Infinity Reference 475a amplifier
(2) Skar Audio V-VXV1 12D4's
Hifonics Brutus 2100.1 @ 1 Ohm
pm me your zip code and ill see
Team gg.
  • 1 month later...
These still for sale?
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
  • Who's Online   0 Members, 0 Anonymous, 1273 Guests (See full list)
