Red to switched ignition and black ground.
pointless. you want to read the voltage at the amp, not the cars fuse box or wherever that switched wire may be.
Your best option is to run it to the amps power and ground and then wire in a relay. It's what I had to do being I didn't want to flip a switch all the time.
1998 Ford Contour
Head Unit: Pioneer DEH-P8400BH
Front/Rear Door Speakers: Alpine SPR-68 (Type-R 6x8)
Door Speaker Amplifer: Kicker ZX650.4
Subwoofers: 1 SSA Icon 12"
Amplifier: MB.Quart 1.1500d
Second Battery: XS Power D925
To clearify, before I go wiring up stuff, a relay would be okay, right?
Just wired the +12 into the amp pos
Ground to amp GND
RmT to Remote Turnon on HU
and then wire the actual volt meter (2 wire)
to the relay and ground, right?
BASS MEKANIK RECORDS
"Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold!
2007 Ford Focus
(NOTE: My cousin's build I helped him with)
Pioneer H/U
(4) Absolute Dome Tweeters on A & C pillars
Scosche HD683A's in front doors
Fosgate R168x2's in rear doors
SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz
Audiopipe APCL-1800.1D
Q-Mat
Audio Technix 0 Gauge
119aH/850CCA Marine Deep Cycle batteries
YouTube Channel: http://www.youtube.com/DWRhythm
I think you want to run ground straight form amp to meter. Hook your relay up to a switched+ and any ground. then run + from amp to one side of realy then off the other side to meter. Is that what you are saying? Don't take my word on this but i think that's right.Also, i think you need a "NO" or normally open relay. Someone correct me if i'm wrong.
i say this because i think most 12v relays are 4 wire. they have pos and negative for switching the relay on/off, then two other pins that are either open or closed that complete the circuit.
Hope i didn't confuse you, do you have a relay we can see before you buy so we can tell you how to wire it?
Also i'm talking about a seperate set of wires from your amps power wires, like some 14ga or 16ga.
Edited by strangeduck
did i not say put it on a switch, which was the FIRST post...damn noone reads anymore i swear....id just use a switch personally insted of a relay, easier and quicker
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Hey, i have a switch on mine! i agree, but the o.p. wants a relay so i was just trying to help. lol
