TheNewbie Posted April 19, 2012 Report Posted April 19, 2012 I was messing around on my Uncles headunit, and then on mine.. and had came up with a few questions. 1. What's the HPF and LPF for? Is it for the speakers? Being that there is one on the amp I was a bit puzzled. 2. When you go into "Subwoofer" on my H/U I get the options for a certain hertz, 50-125 I believe, and then what seems to be a subwoofer level on the side. Doesn't say exactly what it is. Those are the two fairly simple questions I have, for most of you anyways. Any info is appreciated Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
Freshman6969 Posted April 19, 2012 Report Posted April 19, 2012 High Pass Filter(speakers)- sets your h/u freq output to the speakers to cut out anything below that point, Low Pass Filter(for the sub amp) is the oppisite same thing for the sub control, i usally set that at 80hz, same with the LPF, sub level with essentially turn the volume up to the sub to put it simply or down Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
Omega5002 Posted April 19, 2012 Report Posted April 19, 2012 LPF is for cutting higher frequencies, like when you want your sub to play up to only 63 hz, after 63hz, it slopes down HPF is the opposite I believe the options are the LPF for your subwoofer. Edit: Got ninja-ed lol 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
TheNewbie Posted April 19, 2012 Author Report Posted April 19, 2012 I know at they are hpf and LPF but why is one on the heady it and then again on the amp? Is the head units one for the speakers? And if the LPF is the same on your amp as your deck why is it at 80? Maybe I'm confusing myself here lol thanks guys Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
01ExSport Posted April 19, 2012 Report Posted April 19, 2012 For ease of use mainly. Some people turn their LPF/HPF's on their amp wide open, and set it with their headunit so they don't have to get out and tune the amp to adjust a few settings. Plus they're most likely more accurate on a H/U unless you don't have a CC-1.
