So i am going to buy an AQ 2200D friday. Well i was looking at the amp on the aq site and i see 2 sets of terminals. I am wondering do you put each sub into each terminal and the amp wires them together on the inside? Can anyone help me on understanding this? Also maybe a few recommendations i have 540 to spend.
i have that same amp. Yes each sub can get its own set of terminals , the terminals are interconnected inside the amp so you will still achieve the ohm load you are after
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Live the amp. Doesnt get warm at all. Its pushing two SA 10s @ 1 ohm. The real test will be when i wire it to .5 ohms :)
Yes DD-1 . My clip light was kinda close to my DD-1 BUT dont trust those lights. With DD-1 tune it was noticably louder and clearer
oo thanks for the input mike i'm about to get the 1200 :)
wooohoo!
-Acura RL 2005. Blue.
-Stinger Expert Roadkill..Trunk only
-(2) Skar VVX-12's D4 coils
-Dual slot ported to the left custom box tuned @ 32hz
-Audioque 1200D amplifier
A tribe called quest... ftw
No problem.
I have two dual 4 ohm subs. Go to the12volt.com and click sub woofer wiring. I wired each sub to 2 ohms using the dual ohm. Thr wired each sub( each sub is at 2 ohms) to the anp each sub got its own terminsl set, which brought it two one ohm. What subs maybe i can draw up diagram
  • Who's Online   1 Member, 0 Anonymous, 1063 Guests (See full list)
