Help with AQ Amp
KenC210
So i am going to buy an AQ 2200D friday. Well i was looking at the amp on the aq site and i see 2 sets of terminals. I am wondering do you put each sub into each terminal and the amp wires them together on the inside? Can anyone help me on understanding this? Also maybe a few recommendations i have 540 to spend.
i have that same amp. Yes each sub can get its own set of terminals , the terminals are interconnected inside the amp so you will still achieve the ohm load you are after
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Alright thanks... how you like the amp? and what you have it pushing
Live the amp. Doesnt get warm at all. Its pushing two SA 10s @ 1 ohm. The real test will be when i wire it to .5 ohms :)
Yes DD-1 . My clip light was kinda close to my DD-1 BUT dont trust those lights. With DD-1 tune it was noticably louder and clearer
oo thanks for the input mike i'm about to get the 1200 :)
wooohoo!
-Acura RL 2005. Blue.
-Stinger Expert Roadkill..Trunk only
-(2) Skar VVX-12's D4 coils
-Dual slot ported to the left custom box tuned @ 32hz
-Audioque 1200D amplifier
A tribe called quest... ftw
I have two dual 4 ohm subs. Go to the12volt.com and click sub woofer wiring. I wired each sub to 2 ohms using the dual ohm. Thr wired each sub( each sub is at 2 ohms) to the anp each sub got its own terminsl set, which brought it two one ohm. What subs maybe i can draw up diagram
  • Who's Online   1 Member, 0 Anonymous, 1582 Guests (See full list)
