Should I seal my trunk from cabin ?
Hi , I would like to know if I should seal the outside of my box . Will this increse db's ? Here some pictures : imag0017gt.jpg
. You can see a pieces of the frame cover with plastic in front of my port . Does this affect the sound ? . PS my amp is in the back now . Thanks
Edited by max785
2001 civic dx
2 X sa12's "
1 X aq1200d
Knukonceptz 4 gauge , rca
sealing it off is the best option..it keeps the sound going into the cabin...and will lessen the rattle from your trunk...the bit of blockage from the framing wont really cause much of a problem..nothing to worry about anyways...keep your amp in the trunk..and use cardboard to make templates for the sections you need to seal off...its the easiest method...sometimes it will sound a bit different but thats usually when you go from backfiring toward taillights to turining it around to face forward (which your setup already is) so you probably wont notice it sounding different except hopefully louder simply because the space the sound will affect will be smaller due to subtracting the trunk space sound would be getting to...
i would seal off any and every trunk build I have...I did it to my build in my 94 Cavalier..and had no rattle from the ass end...I did 148.4 on the dash in dbDrag in 98 with that setup...i will never run a trunk build thats not sealed forward
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Yes I'd seal it off. You might want to think about just building a new box with a center port or figure out a way to get nothing in the way of that port.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
  • Who's Online   0 Members, 0 Anonymous, 748 Guests (See full list)
