RickyFriery97 Posted April 23, 2012 Report Share Posted April 23, 2012 It's for ease of wiring. On my RF T2500BDCP I have a 2ohm load going into each input. The amp is internally bridged so that makes my final load 1 ohm Quote 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer Link to comment Share on other sites More sharing options...
PURP's 02 Denali Posted April 23, 2012 Author Report Share Posted April 23, 2012 It's for ease of wiring. On my RF T2500BDCP I have a 2ohm load going into each input. The amp is internally bridged so that makes my final load 1 ohm so basically it so that I could use one dist block and run multiple runs of wire and have them all pretty much wired to 1 set of wires so I can have all those wires wired in to one set of speaker wire terminals? does that sound right or am I still off? I just want to know so when I get around to doing my big build I know everything that I can so that I can have it as close to perfection as posible. Quote Link to comment Share on other sites More sharing options...
PURP's 02 Denali Posted April 23, 2012 Author Report Share Posted April 23, 2012 thanks for everybodies help too. I really appreciate it Quote Link to comment Share on other sites More sharing options...
stroupe79 Posted April 23, 2012 Report Share Posted April 23, 2012 Ok so I get why they put 2 terminals on them now thanks. But say I only have 1 sub how would I wire it the the terminals than. And yes I know I am stupid but what exactly does a dist block do I've seen a lot of mixed emotions on here about them so I guess what I'm asking is what is the fuction of it and what are the pros and cons of it? ( sorry for asking so many questions and not knowing anything but I have been trying to do my research) distribution blocks are used to "distribute" the power to your amps...usually when your running 2 amps...say a 4channel and a 2channel/mono amps it is also fused to help protect the amps...for example power from front is fused up front...travels to rear distro block where it is fused (smaller than front) before the power goes out to the amps Quote http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
PURP's 02 Denali Posted April 23, 2012 Author Report Share Posted April 23, 2012 ok thats what I thought but just wanted to clarify. Quote Link to comment Share on other sites More sharing options...
