greenlight00 Posted May 6, 2012 Report Posted May 6, 2012 Get 2 Hifonics hfi 1500.1d's and you won't regret it. I'm sold on Hifonics nice amps that run very cool and have quite a bit of power for the price.
Guest Posted May 6, 2012 Report Posted May 6, 2012 Get 2 Hifonics hfi 1500.1d's and you won't regret it. I'm sold on Hifonics nice amps that run very cool and have quite a bit of power for the price. you must be joking. their hfi series is their bottom line. they dont even do rated power
412 CVX Posted May 6, 2012 Report Posted May 6, 2012 This thread is full of fail. OP needs to do more research and figure out which amp to buy for himself. there have been at least 20 products recommended in this thread, and every time something is suggested, it's on to that product. I've never seen someone change their mind so much Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
greenlight00 Posted May 6, 2012 Report Posted May 6, 2012 2 hfi's are more than enough for 2 cvx's. Bang for your buck you cant go wrong... I have 2 hfi 1000.1d's on 2 12" Mtx ts85's and it beat those subs. I've also seen a American bass xfl dual 2 ohm on the hfi 1500 and it pushed it without a problem. the hfi series is the previous model of brutus amps in a differet heat sink. I bench tested the 1500 last year and it wad 1400+ watts rms at 1 ohm with 14.4 volts.
Guest Posted May 6, 2012 Report Posted May 6, 2012 2 hfi's are more than enough for 2 cvx's. Bang for your buck you cant go wrong... I have 2 hfi 1000.1d's on 2 12" Mtx ts85's and it beat those subs. I've also seen a American bass xfl dual 2 ohm on the hfi 1500 and it pushed it without a problem. the hfi series is the previous model of brutus amps in a differet heat sink. I bench tested the 1500 last year and it wad 1400+ watts rms at 1 ohm with 14.4 volts. yeah how did you "bench test" it? did you use an oscilloscope or dd-1 to test for clean power? or did you just use a dmm or tune by ear? any amp can "push" subs. bang for your buck, you CAN go wrong. i dont understand how people cant grasp this concept. edit: and whats with the 1400+? does that mean it does 2900w?
sweendog Posted May 6, 2012 Report Posted May 6, 2012 I had a brz1700.1 yea it was a decent amp but it also fried my q. They don't even have a gain knob which is annoying. Sundowns and Crescendos can both be stable at .5 but you would need good electrical. If you were going that route you should do a lot more research into electrical and stuff. Getting the kicker 2500.1 and wiring it at 2 ohm would be your safest bet.
412 CVX Posted May 6, 2012 Report Posted May 6, 2012 Any 2 ohm stable amp would be a safer bet than running at .5 ohms. especially with your experience. However, you WILL need electrical upgrades if you're going to run 2000+ watts. I've used that kicker amp before, and it's VERY power hungry, even at half power (4 ohms) i had to be driving in order to keep the amp going. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
paposound Posted May 10, 2012 Author Report Posted May 10, 2012 Any 2 ohm stable amp would be a safer bet than running at .5 ohms. especially with your experience. However, you WILL need electrical upgrades if you're going to run 2000+ watts. I've used that kicker amp before, and it's VERY power hungry, even at half power (4 ohms) i had to be driving in order to keep the amp going. Yes, I´ll upgrade my electric system, i have a Mazda 3, What do you recomended me? Additional battery and alternator? ask the same, which is the optimal plant to place 2 cvx, 2 dvc in parallel!
paposound Posted May 10, 2012 Author Report Posted May 10, 2012 I had a brz1700.1 yea it was a decent amp but it also fried my q. They don't even have a gain knob which is annoying. Sundowns and Crescendos can both be stable at .5 but you would need good electrical. If you were going that route you should do a lot more research into electrical and stuff. Getting the kicker 2500.1 and wiring it at 2 ohm would be your safest bet. OK...
iceman1575 Posted May 10, 2012 Report Posted May 10, 2012 This thread is full of fail. OP needs to do more research and figure out which amp to buy for himself. there have been at least 20 products recommended in this thread, and every time something is suggested, it's on to that product. I've never seen someone change their mind so much Try going to another country and try asking for advice like this when you're not fluent in their language. It's not easy. We had a foreign student in our class and the language barrier was tough. Paposound, your subs are meant to be wired at 2 ohms, your best option is the Kicker amplifier. There are other more powerful amplifiers that will do the same power, but aren't meant for it. If you're determined to use Kicker subs, do it man. People have their preferences, and are giving you options. There are other subwoofers other than Kicker. Do some more research, you may find a better system. Good luck man, and welcome to the forums! POTATO!
