Dbforlife Posted April 28, 2012 Report Share Posted April 28, 2012 It tells me to cut out the old one (slits that has logo in middle) Then im left with just the empty ring, then where do i go from there, cant really see where to mount it with the tabs it has. , also i have to cut the slits in so the billet grille will fit in the outer shell better? It wont just be way behind it out of place, if anyone has any picture logs on how to do it, id appreciate it haha. Quote 1998 GMC Jimmy 4 Dr. -SINGER 275 Amp Alternator -150 FT. Of 1/0 OFC (8 runs) 4 pos, 4 neg. Front-back. -Audioque AQ2200D @ .5 ohm -2 Audioque HDC3 18's Tuned to 27-29 HZ -4 Clarion 6.5's -2 Optima yellowtops Link to comment Share on other sites More sharing options...
BeatBox Posted April 29, 2012 Report Share Posted April 29, 2012 you have pictures of the grill you are putting on? im thinking you would cut around the gmc badge only so that the grill can sit against the stock grill and then you bolt it onto that.... Quote Link to comment Share on other sites More sharing options...
