i dont have the knowledge on it but i would think it would be the same as if you wre using an aftermarket hu...
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
You will need to hook up the dd1 to your speaker outs on your headunit first to find out where they clip. then hook up your line converter and use your maxed unclipped volume to adjust your line out converter to max unclipped again. I assume your converter has adjustable sensitivity. then hook your converter up to your sub amp and adjust its gain.
^^^ thats why i said i dont have the knowledge on it
